TwinTurbo.NET: Nissan 300ZX forum - I expect a *slight* idle change when the AC is on,
Z_Cherub
on July 17, 2008 at 5:29 PM
spraying it is pointless.
posted by Drk93TT
on July 17, 2008 at 01:17 PM
but this is much more noticeable. The idle itself does not change much, but the vibration felt does. It's not a constant problem either, only about half of the time. I'll try tightening it and see what happens. Thanks for the advice.
I'm too stupid to figure this out.
Z_Cherub
20:02:07 07/16/08
Hit the belt with some belt conditioner spray. (n/m)
BobbyT
22:29:10 07/16/08
Thanks. I'll do that when I tighten the belt per
Z_Cherub
09:38:23 07/17/08
Drk93TT
13:17:42 07/17/08
If the tension is way off the squeak won't stop
BobbyT
14:42:51 07/17/08
I expect a *slight* idle change when the AC is on, -
Z_Cherub
17:29:47 07/17/08
maybe you need a new clutch fan clutch (n/m)
300ZMang
18:06:37 07/17/08
Good idea, but I shouldn't. I replaced mine w/ new OEM less
Z_Cherub
20:38:10 07/17/08
Your A/C belt is a little too loose, just needs to be
jzack
23:07:06 07/16/08
Thanks. I wouln't have thought that that could make the
Z_Cherub
09:37:21 07/17/08
